Discussion topic: My inter
This message was authored by: Rebecca140
My inter
hi my Internet is not working at home I have switched it on and off and back on and it's still not working
Re: My inter
@Rebecca140
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
