Discussion topic: My broadband
This message was authored by: kevindarlow3
My broadband
Broadband not working
Re: My broadband
@kevindarlow3
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Avatar for kevindarlow3
My sky broadband
No internet
Re: My sky broadband
@kevindarlow3   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
