Discussion topic: My broadband
Message posted on 08 Oct 2025 05:02 PM
My broadband
Message posted on 08 Oct 2025 05:31 PM
Re: My broadband
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 08 Oct 2025 06:34 PM
Re: My broadband
@Debbie7979 And what sky hub do you have and the make/type off booster that you have bought! Link below is all the sky ones if you look see and say what you have!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Message posted on 08 Oct 2025 08:16 PM
Re: My broadband
My house has very thick walls my wifi hub is in my kitchen at my back door had to buy a wifi repeater from amazon to help the wifi reach the whole of my house but it keeps dropping out numerous times it drops out on my mobile phone I need to turn the wifi off in my settings then connect it again multiple times a day .
Message posted on 08 Oct 2025 08:24 PM
Re: My broadband
@Debbie7979 Sorry, the question asked and not answered does not help solve anything for you, would suggest that you look at powerline with the Wireless/Wired range!
A Repeater is only good if you have a good wireless wi-fi signal or the repeater type is able to work with the sky hub, not knowing either as you do not say then cannot advise you what is best! Take a look at the powerline range linked below!
