Discussion topic: My broadband keeps dropping out
This message was authored by: Damotil
I have sky broadband and it keeps dropping out, I have checked my connection using the App tester and it says it's fine which it clearly isn't. This needs sorting please
Re: My broadband keeps dropping out
@Damotil
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: Gabs4
Same problem here too
