Discussion topic: My broadband keeps doing
This message was authored by: William117
My insernet keep dropping
Re: My broadband keeps doing
@William117
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
