Discussion topic: My broadband isn’t working
Message posted on 04 Oct 2025 10:20 AM
My broadband isn't working
Message posted on 04 Oct 2025 10:40 AM
Re: My broadband isn’t working
@Debora3
Use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
