Discussion topic: Changing public IP address on the Sky Max Hub
Message posted on 04 Oct 2025 10:58 AM
For security concerns, I need to change my public ip on my Sky Max Hub. It appears sky uses sticky ips so even after turning it off for an hour or so, the same ip remains. It also appears that you can't modify the MAC address of the sky router on the myrouter.io admin page. Does anyone know how to do this?
Message posted on 04 Oct 2025 11:22 AM
Re: Changing public IP address on the Sky Max Hub
@octave That's a NO, if your hub is not issued a new wan IP then it is going to take more than an hour off the Network to get one, sticky though the DHCP server is on the sky end there is not anyway around that in the least but longer time OFF the network!
No forcing allowed and the sky Max is very much tight and app interface controlled!
