Discussion topic: My broadband is slow
This message was authored by: Tracey-
I have the gig fast connection but I have black spots and slow connection in my other rooms no matter what I try i can't solve the problem
Re: My broadband is slow
@Tracey- Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
