Discussion topic: My broadband is down but sky are telling me everthing is fine
Message posted on 24 Jun 2025 03:19 PM
My TV and broadband are switched on , I have a blue screen and a notce telling me my broadband is down. I have gone to sky's website, followed all of their instructions, been told everything is fine. It is not!!!
Message posted on 24 Jun 2025 03:33 PM
Re: My broadband is down but sky are telling me everthing is fine
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
