Discussion topic: My box got 2 red lights on it’s not working
Message posted on 22 Dec 2025 06:11 AM
My wifi box got 2 red lights and is not working
Message posted on 22 Dec 2025 07:05 AM
Re: My box got 2 red lights on it’s not working
@Mary-Jane1
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
