Discussion topic: My booster doesn’t seem to be working
This message was authored by: Jaykay28
Message posted on 19 Aug 2024 03:13 PM
Hi, I have a white booster and it doesn't seem to be working
Find out more
Message posted on 19 Aug 2024 04:50 PM
Re: My booster doesn’t seem to be working
@Jaykay28 move the booster close to your Sky hub and try connecting it there if it works then you can move it to a point no more than halfway between where the hub is and where you need the boost. If it doesnt connect when close to the hub it is faulty and needs replacing.
