Discussion topic: My boost box isn’t connected
This message was authored by: Eaves1
My WiFi booster isn't connected to the hub
Re: My boost box isn’t connected
@Eaves1 several possible reasons. First the boister does not match the Sky hub so forcexample you cannot use an old Sky booster with the white Sky Max hub which requires a matched pod extender.. Another common reason is the booster is out of range boosters should be placed halfway between the hub and where you nedd the booster. More help here https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
