Discussion topic: My boardband
Message posted on 25 Oct 2025 03:00 PM
My boardband
My broadband doesn't seem to be working please help
Message posted on 25 Oct 2025 03:06 PM
Re: My boardband
@Sarahgee1
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
