Discussion topic: My Wifi is offline
This message was authored by Megan51 This message was authored by: Megan51
My Wifi is offline
Hi. My Wifi is offline again, it has been offline for a while and I've gone through all of the steps to fix it however it will not work. My router is making a strange ticking noise, thank you.
Re: My Wifi is offline
@Megan51
The ticking noise is sometimes reported by users when the DSL modem inside the hub is trying to connect to the line.
Have you tried running the line test in the My Sky app?
I am NOT a Sky Employee
Megan51
Hi James
I've managed to fix it by using that now. Thank you 😊. It just seems to be a reoccuring issue....
