Discussion topic: My WiFi keeps cutting out
This message was authored by: YB-BROWNE
Every day for the last 5 days my WiFi keeps cutting out
Re: My WiFi keeps cutting out
@YB-BROWNE
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
