Discussion topic: Full fibre Survey
Message posted on 01 Jan 2026 12:31 PM
Full fibre Survey
Is it possible to arrange a pre site visit , to determine route of cable / installation point ?
Message posted on 01 Jan 2026 12:53 PM - last edited: 01 Jan 2026 02:03 PM
Re: Full fibre Survey
No: the timescale and budget of the national rollout doesn't permit that.
If you are in the UK then Openreach will have a paper record of the prospective installation type which is visible at
It's the two text lines below the table which are most useful.
Message posted on 01 Jan 2026 01:12 PM
@TimmyBGood , Thanks for response . Showing as unavailable via the link , Sky messaging to say it is ?
Message posted on 01 Jan 2026 02:04 PM
Then you are presumably in a CityFibre network area and would be provisioned by them. I don't think there's an equivalent lookup though.
