Discussion topic: My WiFi has been dropping out
Message posted on 20 Sep 2025 11:55 AM
My WiFi has been dropping out for about two weeks now, I do the checks via the app but it hasn't resolved it fully.
please help, it's affected our work and and enjoyment in Relax times too
Message posted on 20 Sep 2025 12:35 PM
Re: My WiFi has been dropping out
@Lewcas4
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
