Discussion topic: My Wi-Fi is not working
Message posted on 30 Aug 2025 07:59 PM
my Wi-Fi is not working. I've turned it off and on and it still doesn't work and only the Internet box is showing a red light and I have switched it off and switched it back on and still does not work
Message posted on 30 Aug 2025 08:17 PM
Re: My Wi-Fi is not working
@Jamie252
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
