Discussion topic: Internet problem
This message was authored by: Helen262
Internet problem
My internet keeps dropping out. It has dropped out at least 8 times today. I had someone out a few weeks ago as it stopped working completely. Which I thought was fixed but since then it has been dropping out at least a couple of times a day.
Re: Internet problem
@Helen262
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
