3
This discussion topic has been answered Discussion topic: Multi room box
This message was authored by: mommymole
Multi room box
Hi.
Does a multi room box need to be hard wired into the router? Or is it wireless?
Re: Multi room box
@mommymole
A Q Mini box used with a Multiscreen subscription can get its signal wirelessly from the main Q box (which still needs a cable feed from a satellite dish)
The completely wireless solution is Sky Stream.
Re: Multi room box
@mommymole
Which 'multi room box' are you referring to?
Avatar for mommymole
Re: Multi room box
The little box that connects to sky q.
Re: Multi room box
@mommymole
