Discussion topic: Mrs mansell
This message was authored by: Mansrell
Mrs mansell
Not sure if put leads in right ports as network keeps runnong slow
This message was authored by: pcdoc
Re: Mrs mansell
RJ45 plug only fits in one way. Ethernet Cable from the ONT White box on the wall goes to the 1st socket at the back of the sky hub (yellow sockets) in the one marked WAN/ETHERNET . Other 3 can be used for computer, Mesh main unit etc. BT style socket for your landline ☎️.
Wifi won't be as fast as wired, adding a mesh system makes for better Wifi though.
Regards
pcdoc
