Discussion topic: Mrs Caryl bacon
Message posted on 15 Sep 2025 04:52 PM
Mrs Caryl bacon
Had no internet since Saturday need this for hospital appointment
Message posted on 15 Sep 2025 04:55 PM
Re: Mrs Caryl bacon
@carylbacon
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 15 Sep 2025 04:58 PM
Re: Mrs Caryl bacon
Unfortunately that has no bearing on either the reliability of a connection or the rapidity of a fix.
