Discussion topic: Mr evans
This message was authored by: Lesevans
Mr evans
My sky broad band isn't working
Re: Mr evans
@Lesevans
Your duplicate thread has been removed to prevent duplication of replies.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
