Discussion topic: Mr John Mccullagh
This message was authored by: Duff6beer
Mr John Mccullagh
Hi there i need a sky engineer out or am cancelling my broadband
Re: Mr John Mccullagh
Sorry @Duff6beer but we are customers here so if you have no working broadband connection then try this:
If your ONT shows a red light then have a read of this:
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
@Duff6beer
I was replying to your other post but it was removed as a duplicate. Threatening to cancel your subscription is pointless on here. As @caesarome has pointed out you aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Even if you're able to cancel, early cancellation fees are likely to apply and if moving to another supplier using the Openreach infrastructure will likely mean the fault moves with you.
