Discussion topic: Moving to Sky
Message posted on 13 Nov 2025 11:14 AM
Moving to Sky
Thinking of moving frrom BT to Sky given BTs exorbinate cost. We rely very heavily on the interent so rather than having to change the ssid/password io every device I would want to chanhge then Sky router to match BT. Is this possible? I have heard of some routers using incompatible (to bt) formats.
Thank you
Message posted on 13 Nov 2025 12:25 PM - last edited: 13 Nov 2025 12:29 PM
Re: Moving to Sky
@Colin+Grant No it's a simple thing to match the SSID/Password combination for the quick transission from the BT to Sky, just be sure to keep in a safe place the details for ever should you need to do them again when someone ask's have you done a Factory Reset to the sky Hub, wipeout back to the OOB state!
If you happen to go sky Max then you have to do it all app controled with the My Sky app, web interface before will work after that it get's clamped!
Been Sky/EE/Sky and still using the sky ssid/password from way back and mixed matched from a few devices so there is one ssid one password and one Admin password all mixed and matched over the years, now all on the Asus Routers with split tri band!
Message posted on 20 Aug 2026 11:35 AM
Re: Moving to Sky
I want the details of moving from BT to SKY.
