Discussion topic: Miss Isatou
Message posted on 20 Aug 2026 09:01 AM
Miss Isatou
Message posted on 20 Aug 2026 09:12 AM
Re: Miss Isatou
@manneh1 checknthe lights on yiur Sky hub and use this guide https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 20 Aug 2026 10:55 AM
Re: Miss Isatou
@manneh1
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
