Discussion topic: Moving home
This message was authored by: MarkL4
Moving home
I'm about to move home in a couple of days. When do Sky cut off the current address? Can it be a day or two beforehand?
Re: Moving home
@MarkL4  You're leaving it a bit late if you also want broadband at your new address, Sky need at least 10 working day's notice.
Avatar for MarkL4
Re: Moving home
I've gotten an appointment for installation at the new address. So that's all sorted and welll within the required notification time. My question was to do with cut off times for my current address as I'm now without broadband and not moved yet.
Re: Moving home
@MarkL4 it should be the same day but as the actual work is done by Openreach who can get a bit trigger happy and disconnect lines early. The inconvenient thing where this happens is once disconnected it is effectively impossible to get the service back.
