4
This discussion topic has been answered Discussion topic: Moving home
This message was authored by: CatRed1
Moving home
I've moved from England to Northern Ireland. Will my modem work in my new home?
This message was authored by: cookiemonsteruk Answer
Re: Moving home
@CatRed1
Yes.  The authentication over here is the same as the rest of the uk
Re: Moving home
@CatRed1
Avatar for CatRed1
Re: Moving home
Thank you so much. 👍🏻
Re: Moving home
@CatRed1
But note that you must still book the Sky Home Move service well in advance: broadband doesn't follow an ISP router around the national telephone network, and has to be individually provisioned at any particular address for which there's typically a ten working day minimum lead time.
It's also possible that you are moving to a location with FTTP availability but currently use a Q Hub, in which case it will need replacing.
Avatar for CatRed1
Re: Moving home
Ohh ok. Thank you for that. I'll give them a call.
