Discussion topic: Moving from Superfast 35 to Gigaclear
Message posted on 22 Feb 2025 10:09 AM
Hi
I was hoping someone could help. I am considering moving from Superfast 35 bradband to Gigaclear Ultrafast 400. Does anyone know if i need a Sky engineer to attend on the day of the switch to do anything to my Sky and minibox to make it compatible or will it work automatically?
Cheers
Message posted on 22 Feb 2025 10:14 AM - last edited: 22 Feb 2025 10:24 AM
Re: Moving from Superfast 35 to Gigaclear
Two issues: Gigaclear installs its own optical cable infrastructure so they'll presumably be sending personnel to do that if it's not there already.
You'll then need to reset the main Q box and link it to the new WiFi: Sky typically wouldn't book an installer to carry this out (and there may well be a considerable wait if they did)
https://www.sky.com/help/articles/setting-up-sky-q-connect-to-third-party-router
You might then have to reset and reconnect the Q Mini using WPS from the main Q box.
Message posted on 22 Feb 2025 10:17 AM
Thanks Timmy
That helps 😊
