2
This discussion topic has been answered Discussion topic: Moving Home
This message was authored by: falbs
Moving Home
Hi folks
We'll be moving in the next 6 weeks or so. We have Sky broadband and a Sky Glass Air TV. Does anyone know if we get to keep the same hub after Sky have done whatever's necessary at the new property? I ask because it would be handy not to have to change the password for all our devices.
TIA
Re: Moving Home
@falbs
If you currently use a Sky Broadband Hub then you'd keep that unless you choose to add the WiFi Max subscription supplement to the account.
If you have a Max Hub, you'd keep that as long as the new address isn't provisioned on a CityFibre FTTP circuit.
Either way, it's always possible to log into the new Hub and change its WiFi password to be the one in use previously.
Re: Moving Home
@falbs
Avatar for falbs
Level 3 icon
Re: Moving Home
Perfect, thanks.
