2
This discussion topic has been answered Discussion topic: Mobile devices not loading on Sky Max wifi
This message was authored by: Roy19
Hi all , I've recently joined Sky Wi-Fi max. All smart devices are fine but my iPhones show full connection but can't load web content.
have turned off sky shield - rebooted everything and still no joy.
do I need to change the DNS server in my iPhone settings?
Re: Mobile devices not loading on Sky Max wifi
@Roy19 if other drvices are connecting correctly you should not need to use anything from the default setting of getting the network settings from the hub. Hower if you want you can add a public DNS to the setting change the DNS serring from automatic to manual and add the public DNS below the default settings which are the Hub's IP4 and IP6 addresses personally I add Google's on 8.8.8.8 but Cloudflare at 1.1.1.1 is also a popular choice
I
I
Avatar for Roy19
Many thanks , everythings working now . Have a great day
