Discussion topic: having an issue with my broadband
This message was authored by: sirishach
I am having broadband connection issue with very slow speed (5 mbps)
Re: having an issue with my broadband
@sirishach either click to run the full connection test in the My Sky app which will give youbthe currentvspedd your hub is connected at and if tgst is belowctge minimum for your line it should offer to book an engineer to check your line.
If the speed to the  hub is fine then click to let itvtest the connection to your devices as poor wifi spedds are a common issue.
Alternatively post your hub's connection stats and forum members can probably help see Find your Sky Broadband router statistics
