1
This discussion topic has been answered Discussion topic: Mesh
This message was authored by: AJLP1
Mesh
Is there a sky router that supports TP-Link onemesh ?
Re: Mesh
@AJLP1 no Sky hubs do not support third party mesh solutions.However you can use such a system with your Sky hub simply connect the TP-Link system to the hub by ethernet and disable the Sky Hub's wifi. I find configuring my TP-Link Deco system in Access Point mode as opposed to router mode is the best config.
Re: Mesh
