Discussion topic: Max router slower than previous
This message was authored by: Circa1977
Recently changed my router to the new white sky max router from the older black router but now my speeds are noticeably slower when streaming never had any issues with the older style
Re: Max router slower than previous
@Circa1977 If you stiil have the black hub same style as the white one then connect it back up!
Avatar for Circa1977
I wish I did they sent a box to post it back to them
@Circa1977 There are a few options in the sky max hub that may improve the connectivity of the sky Max hub to the devices, and will require adjusting via your app as that is the only method that can do it. Help link below will give you what may be done, so best to have a read at it first. But will be to do mostly with the WPA Mode operation!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
