Discussion topic: Max pod won't work
Message posted on 21 Apr 2025 01:06 AM
Max pod won't work
Message posted on 21 Apr 2025 06:58 AM
Re: Max pod won't work
If you can move the pod next to the hub for a while and get it to connect, leave it there for an hour or so to male sure it is connected to the sky wifi max hub then move to where to want it in the house, i had the same problem last year when i got my pod as i live in an old house, and that's what i did and it's fine now, i hope this works for you
Message posted on 21 Apr 2025 07:04 AM
@mccowan Go to this page https://www.sky.com/help/articles/sky-wifi-booster-setup-problem-max-pod and follow the steps invluding checking the pod is correctly listed in the My Sky app if it isn't it nedds adding.
