Discussion topic: Max hub
This message was authored by: Williamst83
Max hub
The max hub that has just been purchased is not connecting to the tv. Followed all the instructions and not working
Re: Max hub
@Williamst83
It may be that the tv only accepts wpa2 wifi passwords not the wpa 3 that the max hub uses by default.  On your my sky app go to the wifi settings and select wpa2 or wpa3-transitional
Avatar for Williamst83
Re: Max hub
Did all that managed to finally get it connected. Only hold the wps button for 3 seconds no longer as it factory resets
