Discussion topic: Max hub
This message was authored by: polomint
Message posted on 10 Dec 2024 10:42 PM
Max hub
Hi, Skyvok on old hub, upgraded to sky max hub tried three times it won't connect any suggestions, ( reconnected old hub ) chris
Find out more
Message posted on 11 Dec 2024 06:48 AM
Re: Max hub
@polomint assuming you are conecting the new hub correctly and you have allowed time for it to reboot and connect which takes up to 5 minutes tgen it sounds to be a faulty unit if so call Sky and report the issue to them.
Message posted on 11 Dec 2024 09:52 PM
Re: Max hub
Thanks for your reply Chrisee, I persevered, tried to day disconnected everything installed it with power and Internet only,them added the signal boosters and pucks.Works now found out leave anything to do with sky alone. Thanks
