Discussion topic: Max hub restarting a lot
This message was authored by: Rhh08
Hi my sky max hub has been restarting a lot Iver the oast few days it will reset 2-4 times before it's stable again it does it twice a day, I've had it just over 2 weeks any help please? Thanks
Re: Max hub restarting a lot
@Rhh08  Is the router power cycling or is the connection just dropping out?
Avatar for Rhh08
Level 0 icon
Power cycling I think not sure, it goes through all the lights I don't need to do/touch anything to get it back on it just resets
@Rhh08  If you think that it is power cycling then it would be best to give Sky a call and speak with them regarding changing the unit. But it would be also good it you can check the power outlet it not at fault .
