Discussion topic: Max Hub Settings
This message was authored by: Byron+Wells
Max Hub Settings
Is there any way on the max hub to enable 2ghz settings as well as 5ghz setting?? If so how? Tapo camera c85 only uses 2ghz settings and now cant be found
Re: Max Hub Settings
@Byron+Wells
By default a Max Hub will be broadcasting the same SSID (wireless network name) on both 2.4Ghz and 5 GHz simultaneously.
