Discussion topic: Master socket
This message was authored by: butbob1214
Master socket
Hi I have booked a home move for next month, I explained that the property I am moving to has had the master socket removed and no visable cables. How do I get a master socket installed so that when I move the broadband and phone will work?
Re: Master socket
@butbob1214
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Re: Master socket
@butbob1214
If the master socket has been removed & no FTTP is avaliable to the property then I am afraid you are in for a delay. What will need to happen is you'll have to wait until the activation date of your service, then the day after activation you'll need to call Sky and report you have no master socket. At that point Sky will send out Openreach to fit a new one. As far as I am aware there is no way to get Openreach out before the service is active.
I am NOT a Sky Employee
