12
This discussion topic has been answered Discussion topic: Mail wrong connection cable
This message was authored by: Kun2
l received the hub from Sky,the accessories are one power cable and one cable with both yellow plug ends,missing the cable with the purple plug end.l tried to contact Sky for help, they needed me to enter last4 digits of my ID,l don't know what it is,so I entered the last 4 digits of my account no. ,they told me it was wrong. So, how can I get in touch with Sky and send me back the right cable!Thx!
This message was authored by: cookiemonsteruk Answer
Re: Mail wrong connection cable
@Kun2
The ethernet cable with yellow plugs is sent out for fttp full fibre comnections
@Kun2
This message was authored by: peter-marlow+1966
Look on  YouTube  at sky help setting up  your hub video
P c marlow
@Kun2 if you need a cable to connect to a phone socket as you still have a partial fibre service you can buy one at any hardware store etc just look for a DSL cable with rj11 connectors.
Avatar for Kun2
Thank you, you seem to be right, because in the video tutorial of Sky, it teaches to use purple, but they didn't send me purple. I don't understand this thing at all.
Avatar for Kun2
Hi Cookiemonsteruk, Thank you, you seem to be right, because in the video tutorial of Sky, it teaches to use purple, but they didn't send me purple. I don't understand this thing at all.
Avatar for Kun2
Hi Chrisee, I just want to connect to WiFi, nothing else, but, thank you.
Avatar for Kun2
I have solved it, thank you everyone.
@Kun2 Did you solve it with the exact parts that sky had sent you? And if you did, was it just the instruction label in the box that did not show you the right way to follow and connect?
@peter-marlow+1966 Hi, i tried a PM to you, but as you are on this post could i ask a favour and for you to not hit the likes when you see me.on my responses, Thanks JimM1.
This message was authored by: skyuser20250804
Hi, I met the problem, i only recevide the yellow cable, wihtout the purole broadband cable, just wondering did you end up buying the purole cable by yourself? thanks!
@skyuser20250804 Connecting to a FF Full Fibre FTTP service with a OR Openreach ONT installed, then you DO NOT need the cable with the purple ends...
Thanks a lot! I finally got connected!
