Discussion topic: MAP-T Disable
This message was authored by: sxruh
MAP-T Disable
Does anyone know how i get MAP-T Disable Profile set please?
Re: MAP-T Disable
@sxruh  MAP-T isautomaticaly enabled if you have a white Sky Max or Gigafast hub Sky will only disable it if there is a proven need. Customers can set the sharing ratio to 1:1 themselves by enabling UPnP see UPnP set up
In practice MAP-T causes few issues with most of the early issues with VPNs have been sorted. MAP-T is not used with other Sky hubsxand third party routersxshould not be affected either. If you believe you need it to becdisabled post again explaining why and your post can be escalated.
