Discussion topic: Low speed
This message was authored by: Terribake
Low speed
It saying there a problem with my Internet speed should be 50 it around 25
Re: Low speed
@Terribake As you do not say which sky Hub you are using, try a diagnostic run against your line, then the further test to see if anything is found with your connection.
Try running the line test here to see if any faults are found:
