Discussion topic: Low speed
This message was authored by: Jevgenija123
Low speed
Hi. So low speed. Yesterday was 200, today 100 mbps. When minimum speed is 600.
Re: Low speed
Hi @Jevgenija123
Where are you getting this speed figure from? The Sky line test or a 3rd party tester? If a 3rd party tester is the device connected via WiFi or ethernet?
I am NOT a Sky Employee
Avatar for Jevgenija123
Re: Low speed
From Speedtest app. WiFi. Can't play and watch online
Re: Low speed
Hi @Jevgenija123
Your minimum speed is guaranteed over ethernet, not WiFi. WiFi speeds can fluctuate constantly and the 100mbps you are seeing is way over any WiFi guarantees that Sky have,
Re: Low speed
Thank you for your response but previously it was 500-600 using WiFi    And no issues watching or playing games
Re: Low speed
@Jevgenija123 What does the service checker say you are getting for the 30 day history!
Re: Low speed
This is what I have found:
Problem with your speed?
Your speed looks good, but we haven’t got info about your speed for the last 30 days. ​Don’t worry it doesn’t mean there’s a problem, we just haven’t been able to check if we’ve met your Speed Guarantee.
Re: Low speed
@Jevgenija123 Which sky Hub do you have on the connection! All you can do now is an Ethernet test to check!
