Discussion topic: Low speed
This message was authored by: Gabby96
Low speed
Hiya Sitting next to the router and using ookla speed test while my phone data is switched off and only using WiFi. Downloads on average tonight since 4pm are 126megs Please help. Sky TVs are glitchy because the Internet is so bad and YouTube videos not even loading on TV or on the phone
Re: Low speed
@Gabby96 126Mb/s is roughly 4 times the maximum bandwidth that streaming the most demanding UHD programme requires. The important bandwidth is the one the streaming device receives which is easily found by going into the Netflix app and running the Network test in the Get Help menu.
As important as bandwidth is stability as if the wifi signal is subject to interference data packets go missing causing buffering etc. The symptoms you describe sound to be the very common issue of poor WiFi in your home. In many homes a single Sky hub is insufficent to give usable wifi in every room. The okder the property the more likely this is but brand new homes can also be difficult to network. You could buy Sky's WiFi Max packsgecwhich can supply up to 3 wifi extenders but you msybe better off buying your own wifi equipment.
