Discussion topic: Low speed all of a sudden
This message was authored by: Roy+S
On the 18th sept whilst on holiday our download speed went from 68mbs to between 32-38. When we returned I called sky and the day after an engineer came out.
he said there's 71 going into the router but the low speeds coming out. He swapped the router and it's still 32-38mbs which is well below minimum promised figures.
Are sky throttling my connection? Or can anyone offer advice please
Re: Low speed all of a sudden
@Roy+S Sky do not throttle connections it is likely the fault was not cleared properly. The full connection test in the My Sky app should offer to book an engineer if it doesnt call Sky but mention the history. You are not alone as the recent bad weather has caused loads of similar issues as copper wires carrying, high frequency signals dont mix well with loads of water.
If you post your hub's connection stats forum membersxshould becable to tell you more if you want see Find your Sky Broadband router statistics
Avatar for Roy+S
is this ok? WiFi and Ethernet connected PC 38kps max
@Roy+S
Your stats are showing 73mbps so not sure whats going on. Can you please post a screenshot of the speedtest?
I am NOT a Sky Employee
Avatar for Roy+S
Hi
Thank you, I'll post tonight from home.
all the WiFi items and the Tv show 30's with max 38.
its the same as old router swapped the other day
Before 18 th sept these were all 70's.
Engineer said to allow 2 weeks for router to settle in, but I don't think it will change
regards
Roy
@Roy+S
You need to be testing via ethernet, not WiFi to ascertain whether the issue lays with the line or WiFi
Avatar for Roy+S
Hi
yes I checked the tv as on Ethernet and only getting max 38
thank you
@Roy+S
Only issue is TVs often dont have the best of ethernet chipsets so it may be giving a dodgy reading. Is there any PC you can do it on?
Avatar for Roy+S
Hi
yes ill test the Pc again later  ( both this and TV were 70's) before
Avatar for Roy+S
@Roy+S
Does still seem like you have a limited downstream throughput considering your upload is right. I think Sky need to send Openreach to look at it. I have escalated your post to chat with Sky, look out for a message on the forum
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent Roy+S  an invite to chat.
Lisa - Sky Tech Team Expert
Avatar for Roy+S
Hi Lisa
Sorry been out all day with limited access to phone. Do I need to be home when we chat?
regards
Roy
Avatar for Roy+S
Spoke to Sky on Friday they said again Openresh would contact me me within 72 hours.
Nothing as yet. Had to buy a new PC and downloading all my old programs at 4mbps has been not only painful, but discovered can't steam TV at the same time as buffers constantly.
feeling very frustrated now so maybe it is time to go with Vodafone as they keep asking us
Avatar for Roy+S
