Discussion topic: Lost signal
Message posted on 12 Jan 2026 02:37 PM
Lost signal
Pictures keeps breaking up and then black screen
Message posted on 12 Jan 2026 04:54 PM
Re: Lost signal
@bigboss1st if you arecstreaming using WiFi then the issue is likely to be poor WiFi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
