Discussion topic: Lost connection
This message was authored by: aitor
Lost connection
It suddendly the connection drop
Re: Lost connection
@aitor
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't come back on by 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Avatar for aitor
Re: Lost connection
Thanks for the info, it really helps.
This message was authored by: Mark3710
Re: Lost connection
What do you do when you to says no WiFi. Checked it through the app. Checkers box turned on and off and still no sky from the Q box. I work from home so need the WiFi. Frustrated when watching something and it just goes off
Re: Lost connection
@Mark3710  Is it back working again this morning?
Re: Lost connection
Internet is work as my partner works from home. Not tried the tv yet . But thanks
