Discussion topic: Lost broadband
This message was authored by: Dionne21_
Lost broadband
I have no broadband
Re: Lost broadband
@Dionne21_
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
