Discussion topic: Loss of broadband connection
Message posted on 29 Sep 2025 10:39 AM
Anyone having problems with their sky hub in East Lothian?
Message posted on 29 Sep 2025 10:44 AM
Re: Loss of broadband connection
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
